Advanced Photon Source
Information for Users
Basic information for APS users and prospective users.  Please see the APS users information page, including "My APS Portal," for further details.
Obtaining Beamtime
Beamtime at the APS is awarded competitively, generally via the General User Proposal (GUP) system.Calls for GUPs are issued three times a year.  When a GUP is first submitted, it is rated by the appropriate Proposal Review Panel (PRP) and may be granted time by the Beamtime Allocation Committee (BAC).  GUPs remain valid for up to two years or until they have used up the amount of beamtime which was allocated to them.
If a GUP is not allocated beamtime in a given cycle, or does not use all of the beamtime allocated to it, then users can submit a Beam Time Request (BTR) in future cycles.  The BTR will not be reviewed by a PRP again.  If the GUP's previous BTR was granted beamtime, then it will be evaluated with itsscore.  But if a GUP's last BTR was not allocated beamtime, its score will improve by 0.2 (this improvement can happen up to two times).
Please contact the beamline staff with any questions or for help in preparing your proposal.
Note that being allocated beamtime is distinct from gaining access to the Argonne site.  Refer to the APS website on site access for detailed instructions.
Safety
Safety is of utmost importance to Argonne and to Beamline 7ID.
All experimental work at the APS must be reviewed and approved before commencing.Generally this occurs thru the Experimental Safety Assessment Form (ESAF).  ESAFs must be submitted at least seven (7) days before an experiment is scheduled to begin; more time should be allowed for experiments with elevated hazards, especially if new safety protocols are required.
Users must also complete all necessary training courses before performing any experiments; many of these courses can be done remotely, before arriving at Argonne.
Please contact the beamline staff or APS safety staff with any questions or if any help is needed.
Shipping
Shipping equipment to and from the APS may be subject to DOE, DOT, and/or customs regulations, and must be done properly to avoid confusion and delay.  Refer to shipping resources on the APS website for detailed instructions.
Foreign users: Please pay particular attention to the requirements listed here to avoid customs-related problems.
After Beamtime
Please be sure to clean up your experiment and any beamline facilities which were used.
A chemical waste log must be properly and completely filled out for all chemical waste that is generated.  The form can be found here and can be filled out electronically.
One member of the research team (probably the PI or the on-site spokesperson) should promptly submit an End of Experiment Form.
Inform the beamline staff of any publications which are based on work done at 7ID.
